Found a leak...
Old 02-06-2013, 06:24 PM
matt9589's Avatar
matt9589 is on a distinguished road
Exclamation Found a leak...
while changing out my headlights today, i noticed that i have a leak in the radiator area. not sure what this tube is called but it leaks?? Does it need replaced or it there an o ring gasket type thing there that leaks??
Attached Thumbnails Found a leak...-20130206_173248_zpsefeb223c.jpg   Found a leak...-20130206_173232_zps6fe9bf0d.jpg
Old 02-06-2013, 06:35 PM
Maxboost25psi's Avatar
Maxboost25psi is on a distinguished road
Aint that a transmission cooler line? Shouldnt be hard to fix...part is around 30.00 from what I seen in line...
Old 02-06-2013, 07:07 PM
newguy's Avatar
Tranny lines are on the other side, those are AC lines
Old 02-06-2013, 07:08 PM
newguy's Avatar
May be able to snug it up
Old 02-06-2013, 07:33 PM
matt9589's Avatar
ill try tomorrow. My AC is bypassed and doesn't work.
Old 02-06-2013, 08:48 PM
cleburne red's Avatar
On mine, the ATF cooler is passenger side of the radiator, and driver side (what is pictured) is the oil cooler. The AC system has its own condenser; it's totally separate from the radiator.
Old 02-06-2013, 09:32 PM
Twip's Avatar
not part of the a/c. it should be part of the oil system as stated above. i would take it off, and gently clean it with a wire brush and then put it back on. if you dont clean it, you could possibly break the radiator. they key here is to be CAREFUL!!!
Old 02-06-2013, 09:36 PM
matt9589's Avatar
Great...careful aint my middle name lol. Will I have to drain the radiator to do that?
Old 02-06-2013, 09:40 PM
Nope. A little engine oil will come out, so have a rag or two handy.
Old 02-06-2013, 09:44 PM
Twip's Avatar
nope. that hose goes in there, and comes out near the bottom. that is completely separate of the radiator. if its an automatic, you will have two more going in on the passenger side for the transmission. all four of them tend to weep a little from time to time. you have to be careful of the bottom ones because they can make a mess if you are not prepared.
i recommended cleaning it because of the rust.
Quick Reply: Found a leak...
