Four wheel drive
Old Jan 27, 2015 | 12:11 PM
monkey23's Avatar
monkey23 is on a distinguished road
Default Four wheel drive
Hi I have a 1998 Chevy blazer with the 4.3 l and right now it is stuck in four wheel drive when I press the two wheel drive it will click and the light will just flash and then go back to four wheel drive what should check does it sound like the switch because some days I go out there and none of the lights on the switch are light but then when I press the four hi it will light up again
Old Jan 27, 2015 | 05:56 PM
On your dash switch, are there 3 buttons, or 4?
Retrieve the DTC's and post them in the order they are retrieved. This will require a scan tool capable of accessing the TCCM and BCM. The DTC's will start with "C" followed by four numbers.
Old Jan 27, 2015 | 07:38 PM
dedub2104's Avatar
dedub2104 is on a distinguished road
Default 4x4 problems
There are only 3 buttons
Old Jan 28, 2015 | 06:02 AM
LannyL81's Avatar
Here goes the "broken record"....remove the 4x4 switch assembly from dash. Carefully take the switch halves apart to access the printed circuit board. using a soldering IRON, not gun reflow/resolder every joint, especially at the connector pins.
Re-install and try it again. May solve problem, may not.
Tomblazer
Aug 3, 2007 06:27 PM
1991blazer
Jan 31, 2007 11:22 PM
myhoodie
Jan 14, 2007 04:34 PM
myronhntr80
Dec 7, 2006 02:06 AM
missu
Mar 15, 2006 01:36 AM
