General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
four wheel drive not engaging?'86 s-10
Old Mar 14, 2006 | 09:35 PM
missu's Avatar
missu is an unknown quantity at this point
Default four wheel drive not engaging?'86 s-10
i have a 1986 s-10.it's 2.6 five speed[straight].When i move the lever backword ,the 4-w light is illuminated and the transmission makes a new whining sound, as if the transfer case is engaged,but neither front wheel will pull[spin, when i am stuck]'wonder what the most likely failure would be.thnks for any ideas guys.
Ty
Old Mar 15, 2006 | 01:36 AM
Hanr3's Avatar
Default RE: four wheel drive not engaging?'86 s-10
The most common failure is the vacuum lines. Make sure tehy are in good shape. There are three vacuum lines that run down to the t-case. One provides vacuum tot he switch, one provides vacuum from the t-case switch to the axle vacuum control module next to the battery, and the last one is a vent line and spilts off and attaches tot eh t-case in a seperate place besides the 3 hose fiting.
Make sure the vacuum actualtor is working. Unplug the vacuum line and move the diaphram with your finger. Place your thumb over the vacuum hose hole and see if the diaframe holds. If not, leak. Replace or install a Posi-Lok kit.
robsteez
Feb 15, 2015 10:16 PM
deadeyeden
May 1, 2008 08:43 PM
1991blazer
Jan 31, 2007 11:22 PM
myhoodie
Jan 14, 2007 04:34 PM
myronhntr80
Dec 7, 2006 02:06 AM
