FPR NUT KIT???
Old Apr 11, 2008 | 07:25 PM
Brocktward's Avatar
Brocktward is an unknown quantity at this point
Default FPR NUT KIT???
I found all the parts to replace the FPR except the nut kit?
What is it and can I get by without it or a substitute?
I have to fix it this Saturday.
Old Apr 11, 2008 | 07:45 PM
Default RE: FPR NUT KIT???
You can try, but many have tried to only have leaks later. To have it by tomorrow... Well, you are probably out of luck... The only place that may have it in that short of notice would be the dealership, but I doubt that the parts department will be open on a Saturday. They aren't near me at all...
Old Apr 11, 2008 | 08:11 PM
95_4door's Avatar
95_4door is an unknown quantity at this point
You can call around to local parts stores and ask if they have part number 55163. It is made by HELP! / Dorman Products. Some might have it in stock, some might be able to get it that day.
I would replace it if you can get it.
Good Luck.
Old Apr 11, 2008 | 10:07 PM
Brocktward's Avatar
Thanks, thats what I needed!
Old Apr 12, 2008 | 12:32 PM
Brocktward's Avatar
Ok, I took it apart this morning and there was fuel pooled on both sides of the intake, much worse on passenger side, I will need to replace the nut kit but it wont be here for a week so I replaced the FPR and gasgets and put it back together, it runs much better and more power but I can tell it is still loosing pressure, I will do it again next week to replace the nut kit.
This job was way easier than I thought it would be, I did it on the street in1 hour and 45 min. and I'm not a mechanic.
The Forum is very helpful, Thank You!
Old Apr 12, 2008 | 02:46 PM
95_4door's Avatar
Where are you getting it from? Most places can have it next day. Advance and Autozone can get it next day around here.
Old Apr 12, 2008 | 04:18 PM
You will also want to change your oil. If you have pools of fuel, chances are it drained down to the oil pan as well.
Old Apr 13, 2008 | 01:01 AM
Brocktward's Avatar
I found it at napa, AZ doesnt stock it, I could drive around but I will have to wait for next weekend to fix it anyway.
Ill try the old light the dipstickwith a bic lighterto see if there is fuel in the oil before I drive it monday, I would hate to wash out a berring, I did just change it two weeks ago but I have driven 1000 miles since then.
Thanks for the tips guys!!!
Seems like I have a radiator leak, is itbetter to have it repaired or replaced, any idea what one would cost?
Old Apr 13, 2008 | 11:50 AM
95_4door's Avatar
If you had puddles of fuel in your intake manifold, then you definitely have fuel in your oil. I wouldn't even run it without changing the oil!!
midnightmekanik
Oct 8, 2009 08:32 PM
95LS
Jun 13, 2008 02:18 PM
dragynaz
Feb 24, 2008 01:49 PM
pinktruck
Aug 10, 2007 08:51 AM
whheezzzz
Jun 14, 2007 08:13 PM
