Freeze plug under engine mount
Old Dec 15, 2019 | 10:20 PM
dbelcourt's Avatar
dbelcourt is on a distinguished road
Default Freeze plug under engine mount
My 1995 has been loosing coolant andI've been topping it off for over a year now. I've got the upper intake manifold off to replace the fuel regulator. I assumed the lower intake gasket was the problem. I pressurized the coolant system. Nothing was squirting but I finally found a place dripping. It's coming from the passenger side motor mount.
Even with the wheel off I can't see the exact place where the leak is coming. I imagined it was a head gasket. Looking at pictures of the block, seems there is a freeze plug under the engine mount (dumb!). The other plug, above the starter is dry.
Searched the forum but didn't find any postings about replacing the plug under the mount. My plan is the remove the mount while supporting the engine with a jack and a block of wood under the pan.
The only plug I replaced I ended up using a rubber compression type because I couldn't hammer in a metal plug. Will this be the same deal?
Anyone done this and care to give me some pointers?
Old Dec 16, 2019 | 08:41 AM
eshaw's Avatar
Christine replaced a block heater on her rig. You might want to check that out. Same thing just the ds.
Old Dec 16, 2019 | 12:42 PM
dbelcourt's Avatar
This info on replacing a freeze plug under the engine mount. Not a blazer, maybe a camaro. They made a special tool to press a new plug in.
https://www.thirdgen.org/forums/tech...eeze-plug.html
Someone did an S10
https://www.s10forum.com/threads/any...e-plug.261999/
A good video but the guy took his truck apart. Exhaust, fender, wheel wells, AC, ...
Seems others have asked similar questions but no magic solutions.
https://blazerforum.com/forum/engine...-blazer-90362/
https://blazerforum.com/forum/engine...cations-13072/
https://blazerforum.com/forum/engine...5-blazer-9019/
Old Dec 16, 2019 | 02:12 PM
When I replaced my block heater, it was tight but I did not have anything in the way like it sounds like on the passenger/left side.
Old Dec 16, 2019 | 04:27 PM
dbelcourt's Avatar
There are 2 plugs on each side of the bottom block. The plugs near the firewall are accessible however the other two are under the engine mounts. You installed the heater plug in the rear. No way to fit anything under the mounts. Stupid design...
Wondering if I can get the passenger side engine mount off without removing the exhaust manifold.
A1 Handyy
Jan 14, 2015 04:16 PM
specialty8
Jan 12, 2014 06:42 PM
bizzs
13
Dec 13, 2013 09:21 PM
Jesster
Oct 5, 2012 12:07 AM
babyblueblaze
Oct 19, 2007 05:07 PM
