Friends Blazer starting Issue.
Old Jun 29, 2008 | 03:14 PM
jman_08's Avatar
jman_08 is an unknown quantity at this point
Default Friends Blazer starting Issue.
My friend has a 2003 Blazer and this is the problem is starts great when its warmed up but if it sits over night and the engine is cold It starts hard When its low on Gas it takes forever to crank over. We thought ok it needs more gas we filled the tank. Next morning started quicker but rough turned over and RPM slowly went from 0 to idle speed Only does it when cold.
Would this be a fuel pump issue???
Thanks
Jared.
Old Jun 29, 2008 | 08:17 PM
WolfPack's Avatar
Default RE: Friends Blazer starting Issue.
Could be fuel supply issue, but it could also be a poor spark.. When was the last time you changed plugs and wires? Also do you have access to a fuel pressure gauge?
Old Jun 30, 2008 | 11:52 AM
jman_08's Avatar
I will test the fuel Pressure cold start should be around 65 PSI right?
matt4x4
Jan 6, 2015 02:42 PM
davtak
May 27, 2012 08:41 PM
CarThrower
Jan 13, 2011 01:54 AM
madcowz2020
Oct 30, 2008 02:28 PM
XBlazer01
Aug 7, 2006 02:52 AM
