Front diff Replacement
Old Nov 24, 2017 | 10:13 PM
fletch2270's Avatar
fletch2270 is on a distinguished road
Default Front diff Replacement
Just wondering what the least amount of stuff i have to rip apart to take it out and replace it. Looked into a few threads and there seems to be varying opinions. I am mostly concerned with steering/suspension parts. One thread mentioned they didn't have to touch any of it.
Done lots of DIY repairs on my trucks. First time doing anything major on the Blazer though. It's a 2004 Full size 6cyl 4x4 btw.
Got the replacement from the wreckers. Looks like the side seals will have to be replaced. Anything else I should look at before I do this swap?
Old Nov 25, 2017 | 01:33 AM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
You have to disconnect actuator cable, ball joint, tie rod, drop A arm pull the hubs from CV shafts,remove shafts,unbolt housing from frame and wiggle out.
Old Nov 25, 2017 | 11:54 AM
fletch2270's Avatar
both ball joints and remove the whole thing or will just the lower ball joint give enough room to pop the cv's out?
Old Nov 26, 2017 | 12:11 AM
Upper to get A arm out of the way and lower to drop lower A Arm enough to pull hub free from CV shaft. Or alternatively you could remove hub completely from spindle and possibly leave lower ball joint alone to do the same. Once you start disassembly you will see what needs to be done to remove it. I left the hubs attached to spindles, pulled A arm down to get them free from shaft and removed the shaft. This was for removal from salvage vehicle, ZR2, I did not reinstall on mine. (Yet )
tofunater
Jan 14, 2011 08:11 PM
97tdblaze
Jul 9, 2010 09:17 PM
dagda
Jan 12, 2010 06:37 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
slayer6x6
Dec 8, 2005 02:24 PM
