Front driveline rotating?
Old Sep 25, 2011 | 07:01 PM
rrruschman's Avatar
rrruschman is on a distinguished road
Default Extension Housing Differences
Ok everyone I had a earlier post of driveline rotating and finally think I figured out why the drive shaft is sitting lower. Was trying to figure out why front drive shaft decided to start rubbing on the transmission crossmember in the u shaped area. Well after looking hard at it, it looks like there is a difference in the extension housing. I installed a used transmission from a same year vehicle and just bolted the 233c transfer case to the other one without changing extension housing. After looking hard it put the transfer case in a different position rotaing it up another 1 1/2 inches so now gotta pull transfer case back out and do that part of the job again. I dont know why the extension housing just has a slight difference because came off same year and was a 4 wheel drive also. Anybody got any thoughts on that.
Old Sep 25, 2011 | 07:20 PM
Sounds like you have found the source of your problem. Still doesn't explain why it took so long to show up, but there were a few different adapters used depending on which transfer case you had.
04chevytahoe
Jan 8, 2014 09:13 PM
coolcat0285
Dec 2, 2012 06:29 PM
bill9000
14
Jan 7, 2011 07:54 AM
Oldstoner
Lifting Tech
Dec 2, 2010 08:58 PM
wildboar
May 29, 2006 04:35 AM
