Front end noise help?
Old Aug 16, 2012 | 10:39 PM
dchomie87's Avatar
dchomie87 is on a distinguished road
Default Front end noise help?
OK, I have a 03 Blazer 4DR 4X4. I am hearing like a thump or a thud noise every time I hit a bump. Coming from just in front of like the passenger seat. So I brought it into the shop (I'm a technician) and shook down the front end thinking it was maybe a ball joint or stab link. I found that the LF lower ball joint was bad replaced it and I also looked at the stab links and they look brand new no cracks in the bushings or anything. Test drove it still heard the same damned noise and its driving me crazy.
P.S. I couldn't find any TSB's on Mitchell so I'm hoping someone on here has had a similar issue and could point me in the right direction.
Old Aug 16, 2012 | 11:52 PM
Rottidog's Avatar
Ok you're a tech so the suspension shake down should be cut n dry.
A sorta common issue are the conical washers for the hood. To test this theory you put a small rag that's folded a bit under the side (close to the hinge, on top of the weather stripping) you think the sound is coming from.
Been there, seen it, done it! If the noise goes away then you know it's the washers for the hood hinge/s. Simple & free & on my ride I was looking behind the glove box & wrapping chit up before I heard about this.
Odd sound as it sounds to be coming from the interior because the hinges are under the cowl & resonate in the cab - it throws you.
Old Aug 17, 2012 | 06:41 AM
dchomie87's Avatar
Yea that's exactly where it sounds like its coming from I was thinking about ripping out the dash... Guess I won't have to. So any ideas on some permanent fixes?
Old Aug 17, 2012 | 09:35 AM
Rottidog's Avatar
Getting the conical hinge washers & replacing them.
Not sure on the part # but a GM dealership should be able to get them for you.
Old Aug 17, 2012 | 01:14 PM
50lb_cat's Avatar
BLAZER97LS
Apr 16, 2012 02:56 PM
Chrismacster
Apr 2, 2009 06:57 PM
Hanr3
May 14, 2008 09:35 PM
desertirish
16
Mar 28, 2007 08:01 PM
Jim RN
Jun 28, 2006 03:51 PM
