Front End Popping In Reverse
Old Oct 28, 2011 | 05:52 PM
GermanGeorge's Avatar
GermanGeorge is on a distinguished road
Default Front End Popping In Reverse
My 2002 2WD Blazer makes a loud popping/clunking noise from the passenger side front wheel (pretty sure its passenger side) while I am backing up and turning the steering wheel hard to the left, it started about 6 months ago, took it to the shop, but they could find no problem, at that time it was fairly intermittent, now it has progressed to where it does it every time, and also has the added symptom of a binding/bumpy feeling in addition to the popping noise, and again, this only happens while backing up slowly from a dead stop, and at the same time turning the steering wheel hard to the left. Anyone out there have the answer, I sure would appreciate it!!!
GermanGeorge
Old Oct 28, 2011 | 06:51 PM
trucktom's Avatar
trucktom is on a distinguished road
sounds like upper control arm bushings. roll back slow, have someone watch the top of wheel while u stab the brakes and look for movement at the top of the wheel, you will def know when u see it. for the heck of it look at the bottom coil of the spring look for a broken piece and make sure shock buchings are ok, just pry the bottom around and the stem up top look at for sign of wear aor if you can wobble it around by hand
Old Oct 29, 2011 | 08:25 PM
Thanks trucktom, I tried that out, but didn't really see anything, got any more ideas?
Old Oct 29, 2011 | 08:43 PM
89DropTop's Avatar
89DropTop is on a distinguished road
have you checked the ujoint knuckel? i had that too in my 89 blazer. we took it off and there was a lot of movement. it started off as just happening in reverse but after a while it was noticeable while in drive as well as reverse
Old Oct 31, 2011 | 06:54 PM
Thanks 89DropTop, already did that though.
GermanGeorge
Old Nov 11, 2011 | 08:06 PM
jimnva's Avatar
jimnva is on a distinguished road
Default Front end noise
My 95 S-10 was doing the same thing. I had 3 ball joints replaced before I found out it was a hub bearing. Sounds strange but after I replaced the hub(it is sealed unit) the noise went away. It drove me and a few mechanics crazy trying to find the noise. I, too, thought it was the bushings and bought A-frame bushings but never put them in.
Old Nov 13, 2011 | 10:13 PM
Hey jimnva, are you talking about wheel bearings?
Old Nov 17, 2011 | 09:39 PM
jimnva's Avatar
The wheel bearings and hub are a sealed unit. You have to replace the entire hub .
Old Nov 18, 2011 | 12:38 AM
Thanx jimnva, I'll check that out, I know thats how they were on my Dodge P.U., sealed units, I don't know about the Blazer yet, but on my Dodge they WERE NOT CHEAP!!!, Thanx again.
bam_9_9_9
24
Dec 28, 2010 07:58 PM
sschuler
Jan 5, 2009 03:43 AM
therealdeal770
Sep 21, 2007 10:20 PM
Joey P.
Jun 4, 2007 09:33 AM
bob the blazer
Suspension Tech
Jun 16, 2006 10:13 PM
