Front End Wandering
Old Oct 24, 2008 | 10:37 PM
Blazer4U's Avatar
Blazer4U is an unknown quantity at this point
Default Front End Wandering
I'm having trouble with the front end wanting to wander. Hit a small bump in the road and the Blazer wants to drift off. Pretty hard to drive it most all the time. I haven't had it but a few months. 246,000+ miles. Don't have a good history of the vehicle. I have replaced the front wheel bearings and the rotors and had to replace pass. side stabilizer bar/control arm link that was totally missing when i bought it. I jacked it up and tried wiggling the tires up and down - back and forth. Not really much play from what I've observed before on other vehicles. Where is all the play most likely coming from? I swear this thing makes me think a piece of the front end is going to come flying off the front end when I'm headed down the interstate. Hope someone can give me a clue on this.
Old Oct 25, 2008 | 11:28 AM
catdogs's Avatar
catdogs is an unknown quantity at this point
Default RE: Front End Wandering
Tie rods and ball joint are the most likey culprit
Old Oct 25, 2008 | 01:28 PM
z28jeff's Avatar
z28jeff is an unknown quantity at this point
If you're sure you're not getting any play in the front suspension components, then you need to check the steering coupler (aka rag joint). If that's ok, then it's probably your steering box. My Jimmy has 170k and there's a little play in the steering box. Your Blazer has 74k more miles than mine, so it could very well be it's just worn out. It happens.
Old Oct 27, 2008 | 09:27 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
Replace your shocks. You'd be suprised how it will clear up your wandering front end.
Muddigger86
Feb 8, 2014 09:41 AM
Istr810m
Jan 18, 2014 10:04 PM
schollianmj
Dec 1, 2011 03:46 PM
88blackzcand95blazer
Dec 19, 2008 08:13 PM
jeremysbarlow
Nov 9, 2007 12:05 AM
