Front of motor oil leak.
Old Jul 5, 2014 | 05:46 PM
litterbox99's Avatar
litterbox99 is on a distinguished road
Default Front of motor oil leak.
I removed the front plastic skid plate from my recently
purchased 98 4WD Blazer. I wanted to get a look at
my suspension as I bought new sway bar bushings.
What a wonderful view and better access to what I need.
The down side, the whole front of the lower motor and anything
close by is covered with caked on oil and dirt/mud. including
the remote oil filter. I cant tell where it's coming from until I clean
it up. The mosquito's were bad so I'll get up in the morning
with a power washer and related tools to get it clean.
What are the common leak points for something with 145000 miles.
I've never saw anything on the drive way, but with that plastic
skid plate, I wouldn't.
Just venting...
Old Jul 6, 2014 | 06:55 AM
LannyL81's Avatar
After cleaning, check that all the oil pan bolts are present, especially the front two.
I think that '98 models had the plastic front cover along with the crank sensor; both prone to leaking oil. Trouble is to replace the plastic cover requires ALOT of work as the front differential prevents the oil pan removal...which is required to get to the gaskets.
Another oil leak area is the rear main seal. Which is also ALOT of work as the transfer case and transmission have to be dropped.
The remote oil filter lines also are prone to leaking and required new seals/gaskets at the joints. Much easier to replace. I think most just replace the lines as well.
Overall the Blazer is a very reliable vehicle, but does have it quirks.
Old Jul 7, 2014 | 06:26 PM
Weather was good so I took some more time and replaced the front
sway bar bushings, 4WD vacuum actuator, cable & switch.
Good news ! 4WD works now.
Now I have to drive it to look for leaks.
ComputerNerdBD
Mar 20, 2013 12:33 AM
lionel2
Mar 14, 2013 05:09 PM
BubbaBrooks
May 18, 2011 08:38 PM
totalljen
Sep 17, 2010 11:56 AM
TAZ454
Jan 28, 2008 10:11 AM
