front nose aassembly
i have a 2001 blazer, which recently got into a fender bender. it needs a front clip coolers ect, but i was wondering what the easiest way to remove the front clip is so i can actually see what im working with? thanks if anyosne knows or has any ideas.
sorry fixed my typos, was trying to post from phone.
Look-all this info is here on this site. But guess what? You have some learning to do! So many of these blazer/Jimmys are totally interchangable-you just have to do the homework from year -to-year! If you are not a wrench or a body skilled fella,then these are the cars for you!If you are only dealing with parts swaps! Fairly strait forward with only minor adjustments...
I don't know if I would try to remove the clip as a whole-access is a PITA for many fasteners. Hopefully you hit the right side otherwise you will have to deal with ABS modules! As I stated they are MOSTLY interchangable but one does have to be cautious as connectors changed from year-to-year. I did a 96-to-97 swap(hit right front) and it was almost simple! My neighbors thought I was nuts! HMMM... maybe they know something I don't??? Good luck!
Allan
May 18, 2014 11:03 PM
Wisco Blazer
Nov 30, 2011 02:23 PM
shawn
Mar 22, 2009 05:58 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
