front nose aassembly
Old Apr 2, 2012 | 09:15 AM
bmwallace_88's Avatar
bmwallace_88 is on a distinguished road
Default front nose aassembly
i have a 2001 blazer, which recently got into a fender bender. it needs a front clip coolers ect, but i was wondering what the easiest way to remove the front clip is so i can actually see what im working with? thanks if anyosne knows or has any ideas.
sorry fixed my typos, was trying to post from phone.
Old Apr 2, 2012 | 05:32 PM
step66's Avatar
Look-all this info is here on this site. But guess what? You have some learning to do! So many of these blazer/Jimmys are totally interchangable-you just have to do the homework from year -to-year! If you are not a wrench or a body skilled fella,then these are the cars for you!If you are only dealing with parts swaps! Fairly strait forward with only minor adjustments...
Old Apr 3, 2012 | 05:00 AM
i looked on here looking for info on just changing it back to another stock front end. found alot for the first gen not so much for the second gen. im fairly compentent in my wrenching skills. guess what im really wonder is are the fender rails tacked onto the firewall or is it bolted. dont tell me to go check the truck please.. its still over 100 miles away just trying to gain some pointers n tips before i tear into it. if i cant anything else ill document The work im going and post it up. good info for someone down the road
Old Apr 3, 2012 | 04:19 PM
step66's Avatar
I don't know if I would try to remove the clip as a whole-access is a PITA for many fasteners. Hopefully you hit the right side otherwise you will have to deal with ABS modules! As I stated they are MOSTLY interchangable but one does have to be cautious as connectors changed from year-to-year. I did a 96-to-97 swap(hit right front) and it was almost simple! My neighbors thought I was nuts! HMMM... maybe they know something I don't??? Good luck!
Allan
May 18, 2014 11:03 PM
Wisco Blazer
Nov 30, 2011 02:23 PM
Kirk-NJ
Feb 19, 2010 07:45 PM
shawn
Mar 22, 2009 05:58 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
