Front pinion seal
Old Aug 4, 2008 | 03:59 PM
joey's Avatar
joey is an unknown quantity at this point
Default Front pinion seal
Greetings,
I just have a quick question- what is the torque spec for the front diff pinion shaft nut? When replacing the seal, I thought the torque spec would be in my service manual and turns out it wasn’t. After reading a few post, I discovered that you need to record the free spin torque before disassembly. However I didn’t. Howmuch should I torque the nut?
Thanks,
Joe
Old Aug 4, 2008 | 07:20 PM
Default RE: Front pinion seal
You don't torque the nut... You are in a particularly bad spot at this point in time... You typically would mark the orientation of the nut on the pinion threads and then remove it. Tightening it back down until you aligned the marks with the proper amount of thread showing. You are basically going to have to wing it.
Old Aug 4, 2008 | 10:32 PM
WolfPack's Avatar
What happens if you wing incorrectly....
Old Aug 5, 2008 | 08:29 PM
joey's Avatar
Got everything back togeather. Didnt get crazy over tightening the nut and everything seems normal (after 150 miles). Keep my fingers crossed. Live and learn I guess...
Old Aug 5, 2008 | 08:40 PM
Glad you got it all back together. Hope everything works out for you!
ComputerNerdBD
Aug 9, 2011 08:04 AM
deedub711
Apr 19, 2011 09:11 PM
blaze1002
Dec 6, 2008 03:00 AM
ahawks47
Aug 1, 2008 03:00 PM
mikepro
Sep 27, 2007 06:00 PM
