Front Rotors
Front Rotors
I was at the junk yard today pulling a front left caliper, FL bracket and 2 sets of FL pads. Going back tomorrow for Front Right pads that match the ones I just got today. I bought a digital measuring instrument, and I am wondering how I can use it to see if the rotors are good, or do I need a micrometer?
My safety inspection noted a possible siezed caliper. While braking the vehicle tends to go to the left. It also noted I need a new front left brake hose.
I am headed their tomorrow determined to get the other good thick pads, and the front left brake hose line. Probably return the thinner set of pads, I just wanted to see if the 2000 pads are the same as the 1998 Blazer/Jimmy pads.
Then I am going to have to eyeball the parking brake cable, I assume theres one central inner cable, that splits into 2 for rear left and rear right.
Then its off to the shop for pitman and idler arm replacement.
You'll need a vernier caliper or a micrometer to measure the rotors. New rotors are cheap for these things, have you checked with a parts store?
If the vehicle pulls left while braking, the left one is working. The problem is on the right side. Brakes don't work better when there's a problem
Calipers and rotors a very inexpensive. Why would you ever go to a junk yard to buy those parts. There is no guarantee that they are any better than what you have and could be even more dangerous than your current situation. The thickness of the pads will be determined by the brake system that is on your vehicle. just because one pad may be thicker than another set does not mean they will fit your vehicle. Also measuring the rotors will not tell you if they are warped either. They are in a junk yard for a reason.
x2 on the problem being the right rotor. In the past I could change lanes with a quick tap on the brakes when I had a stuck caliper.
You will need to mesure the full rotor surface to make sure it falls within spec even at the deepest groove. Most likely you are not getting a set that is worn out but still never hurts to check.
I picked up 2 front 4wd rotors for under $50 at the local parts store. They were the cheapest they had but are more than enough for what I'm using them for.
There's a lot of stuff I'll get at a junkyard, but pads/rotors ain't one of them! Probably they're fine, but with brakes, it's better to get new. Heck, I won't even turn rotors. Just buy new if they get too bad.
When I rebuilt my front end I did a brake job at the same time. I nabbed a set of front rotors from a junk yard for $10 and had them turned for free by a buddy at a local shop came out basically brand new. I DID however put new pads on it lol no way I'd install used brake pads...
That's the truth! I use to turn all my rotors but my local parts store stopped turning because of the price of new rotors.
