Front Suspension
Old Jan 12, 2009 | 09:03 PM
KC_JORDAN's Avatar
KC_JORDAN is an unknown quantity at this point
Default Front Suspension
ive got a 99 blazer ls 4d w/ 4x4. front right corner is sagging really hard. noticed that 3 of 4 sway bar link bushings were missing.. replaced all pushings and bolts on both right and left side. still the suspension sags on the right front. has new shocks, wheels barrings, and ball joints. whats wrong?
Old Jan 12, 2009 | 09:05 PM
Default RE: Front Suspension
Torsion bar needs to be cranked up. Follow the bar that runs from the lower control arm back to the cross member. There will be a large bolt there that you can tighten to level out the front end. If that bolt ends up bottoming out, then the torsion bar will need to be replaced.
Old Jan 12, 2009 | 10:18 PM
NVANZEE's Avatar
do you know where to get a good one. the cheapest i found was $200 at the dealer
Rottidog
Jan 26, 2010 07:37 PM
shawn
Mar 22, 2009 05:58 PM
Marcin
Suspension Tech
Jan 25, 2007 06:08 PM
cimbali
Jun 30, 2006 05:07 PM
95chevyflames
Suspension Tech
May 8, 2005 07:20 PM
