FUEL GAUGE AT E, LOW FUEL LIGHT ON. NYS inspcect OVERDUE.
Old 07-08-2019, 08:56 PM
GeorgeLG's Avatar
GeorgeLG will become famous soon enough
Glad your making progress. I'm "wired" for proper analysis and a targeted fix, not parts swapping but it would appear that most people actually prefer the later.
George
Old 07-11-2019, 10:26 AM
hac's Avatar
hac
hac is offline
hac is on a distinguished road
Talking thank you
A sincere thank you for your help. All good, nys inspected today!
Old 07-18-2019, 04:19 PM
bwallace541's Avatar
bwallace541 is on a distinguished road
Default Think I have same problem
Originally Posted by hac
Ran a new low reference wire to pcm. Gauge working, low light off. Won't say its fixed till I put miles on it, but all looks good, ran it a couple times, no pending codes. I'll confirm it in a couple days THANK YOU
So what exactly was the issue. I need mine fixed ASAP
Old 07-18-2019, 08:39 PM
hac's Avatar
hac
hac is offline
Red face The problem was
After trans was installed both wires on the circuit tested open, as if the shop forgot to plug in a connector, or possibly broke both wires. I traced continuity of those wires from pump connector up to the connector on left side of trans. Couldn't go higher, no room. Had continuity. Then tested from that point to computer, and circuit was open. Problem somewhere above trans. Wasn't going to drop trans. So I ran completely new wires from the chassis harness up to the computer in the engine compartment. If your going to do it, I STRONGLY suggest hard wiring (soldering) your new wires in. Cut the wire, don't tap into, it may be intermittently grounding, that would cause issues. I STRONGLY recommend using shrink tube to protect your soldiered connection. Do it once, do it right. Butt connectors can fail, they can also corrode. Not worth the chance.
KEEP IN MIND my pump is less than 1yr old, and I pulled pump, tested the pump float by putting ohmmeter on the 2 wires for the sending unit, raised the float and watched the resistance change on meter. It was fluent, not jumpy, tested it up and down many times, looking for intermittent failure. That verified a good sending unit. If your pump is old, it may very well have a bad sending unit, although the pump itself still performs as designed. Any further assistance, I will MORE than happy to help any way I can
pjf1313
03-09-2016 09:15 PM
phatnogin5877
05-29-2012 07:12 PM
fun2b1
30
07-16-2008 05:27 PM
fun2b1
04-04-2008 11:06 AM
Quick Reply: FUEL GAUGE AT E, LOW FUEL LIGHT ON. NYS inspcect OVERDUE.
