Fuel gauge no longer works after stuck in snow bank
So long story short...we got a foot of snow and I tried to go to work. Was doing fine until I hit the drift that came up over the hood. That pretty much stopped the truck :-(
Managed to get out after about 30 minutes of idling and going back/forth in my tracks.
Had a full tank of gas when that started. Sometime during the struggle to get out of the drift the fuel gauge suddenly went to empty and the idiot light came on.
A little later that day the SES light came on. I haven't pulled the code but will do that tonight.
The entire underside of the truck was one block of snow/ice so I suspect something got water forced into its connection and isn't happy.
Since then the ice/snow under the truck has melted and all connections look ok, but still no gauge and the SES light still on.
Anyone ever had this issue and know the problem? I'm guessing I'll have better luck diagnosing once I pull the error code. It might point me to what's wrong.
I don't suppose there is a separate fuse just for the fuel gauge???
Pulled the code just now: PO452 or P0452 Not sure if it's a zero or Oh.
Powertrain - Evaporative Emmisson Control System Pressure Sensor Low Input.
Cleared it and it didn't come back on until I shut the truck off and started it again.
Web shows: Fuel Tank Presure Sensor Circuit Low Input Conditions.
I assume that would be the same sensor/wire that has something to do with the fuel gauge not getting a signal?
Ah. I should have been more specific. I need to know which wires that run under the truck go to what. I assume my problem is one of the two/three connectors that are on top of the fule tank but I'm not sure.
Two problems going on: When the fuel level sender circuit shorts to ground, the dash gage indicates empty. The P(zero)452 is indicating low input which means there's an open circuit in the pressure sensor circuitry. The wires for both components are in the same harness going to the fuel pump module. Might have to wait til May or June, when the snow finally melts away, to find the problems
So it's probably one of those two sets of wires I saw on top?
Yeah, it's heading to -3 at the moment and there isn't a snowless spot to work on the truck.
I wish I could bring it into the garage and put a heater on so I could work.
Yup, the level sender is inside the fuel pump module, right next to the pump. The sender has two wires and the fuel pump has two wires, all 4 wires are in the same connector on the top of the module. The pressure sensor is mounted to the top of the module and has it's own separate connector. The harness runs along the left frame rail, probably packed with snow! I'm not that far away from you, so I know what you're talking about with the snow & cold, not fun.
