Fuel gauge no longer works after stuck in snow bank
Backed it up onto my ramps and checked those 2 connections. White plug is the fuel pump (disconnected an no start) so the black one must be the sending unit?
Unplugged it and the inside was nice and dry. All 3 wires seem intact. Plugged it back in and still no fuel gauge : - (
The fuel pump module connector has 4 wires: Grey & black, (power and ground) for the fuel pump. Purple and black, (signal and ground) for the fuel level sender. The other connector is for the fuel tank pressure sensor.
Make sure the ignition is in the off position. Disconnect the fuel pump module connector, (4 wires) from the module. Momentarily turn the ignition to the run position, and back to off. The fuel gage should indicate beyond full with the ignition in the run position. Post your results.
Guest
Posts: n/a
I could be wrong but I believe our fuel gages work on ground resistance. Check the black wire one an ohm meter, it should show less then 5 ohms resistance.
This was on a different gm in the way back machine but I seem to remember wiring a variable resistor in parallel to another ground and being able to dial in a fuel gage to correct it's reading.
20+ years ago so take it for what it's worth, but you might want to google fuel gage tuning or something like
Best of luck!
PS What's a Viking dry suit?
Best of luck!
