Fuel Gauge wiring diagram ?
Old Jul 25, 2010 | 05:26 PM
mfd70's Avatar
mfd70 is an unknown quantity at this point
Default Fuel Gauge wiring diagram ?
Hi all, Since I have now sorted some of my issues out, 4WD now working properly, P0104 error sorted etc. I would like to sort out the fuel gauge issue. It always reads empty with the low fuel light warning light on. I've checked the fuel gauge diagnosis page and guess it's probably a ground problem. However I've also noticed the oil pressure gauge doesn't return to zero when ignition is off, or when gauge fuse is pulled, but does return to zero when engine starts and then reads normally, again, ground problems I guess ?
Anyway, does anyone have wiring diagrams for the fuel gauge circuit and the whole gauge cluster circuit (haynes has nothing in their manual). I'm sure it would be easy to sort out once I have a daigram.
Thanks.
PS 1999 Blazer 4.3 (RHD UK Spec)
Old Jul 25, 2010 | 05:37 PM
These should help:
Attached Thumbnails Fuel Gauge wiring diagram ?-99_clstr_1of2.jpg   Fuel Gauge wiring diagram ?-99_clstr_2of2.gif
Old Jul 25, 2010 | 05:44 PM
mfd70's Avatar
Brilliant, many thanks.
Will report back when I locate fault.
Old Mar 25, 2011 | 03:14 PM
seeder7's Avatar
seeder7 is on a distinguished road
I was wondering if you ever found a solution to this problem? I am having the same problem with my Blazer as well, and it really is getting annoying. If you could make some suggestions that would be great. Thx.
Old May 12, 2011 | 05:56 PM
gator 101's Avatar
gator 101 is on a distinguished road
Iput a new fuel pump in, now my tank always shows empty. I checked the wires, it is hooked up right. Any suggestions on what i should do?
Old May 12, 2011 | 06:28 PM
Assuming that the gauge worked correctly before the pump swap, I would have to say that you did something incorrectly. There is a Tech Article on gas gauge diagnosis that will run you through the checks.
jkostic
Jun 9, 2015 02:49 PM
phxjosh
Oct 30, 2013 10:03 AM
hoppy26
Jan 26, 2012 02:08 PM
Mulisha
Mar 24, 2008 09:14 PM
ImJonahearMeRoar
Apr 9, 2007 12:25 PM
