FUEL INJECTORS - UGH!
Old Nov 19, 2007 | 02:31 PM
LittleT's Avatar
LittleT is an unknown quantity at this point
Default FUEL INJECTORS - UGH!
Can anyone help me?
I just replaced an injector on my '97 4.3L, put everything back together and when I went to start it ... there was a POP and wouldn't start. [:@] Hmmm ... the injectors where routed correctly. I put the retaining plate back on, so I doubt an injector would pop out the spider. But I'm not sure. It doesn't want to start correctly.
Also, when I received the spider assembly I purchased, it was an updated assembly to electrical injectors instead of mechanical. If I put these in is there any other conversion pieces I have to add? Or can I just plug 'em in????? The set up is the same ...
Old Nov 19, 2007 | 06:34 PM
hernandez3674's Avatar
hernandez3674 is an unknown quantity at this point
Default RE: FUEL INJECTORS - UGH!
i take it you bought the MFI replacement unit.. take a look at the file attached and verify installation was done correctly.
http://members.shaw.ca/betterthanyou...g%20Poppet.htm
Old Nov 19, 2007 | 07:32 PM
blazeofglory's Avatar
blazeofglory is an unknown quantity at this point
Melanie,
Did you remove the distributor during the upgrade? ( I'm assuming you did) If so,verify that you haven't reinstalled the distributor 180 degrees out.
Just a thought.
Gator
michaeljwyo
Nov 8, 2009 01:03 AM
chris015
Jul 2, 2009 06:40 PM
95Blzr
May 2, 2008 07:32 PM
blazer123456789
Jan 11, 2007 11:26 PM
