Fuel Issue: Wet Spark Plugs and Misfire on cyl #6; passed every other test
Old May 11, 2022 | 07:38 PM
RedBolide's Avatar
RedBolide is on a distinguished road
Originally Posted by GeorgeLG
Some things to consider, from my misfire article:
7) Injector function
At the harness connector, check for proper battery voltage at the power feed for the injector (pink for most modules). Check for pulse control with a noid light or test probe on all cylinders. Consider an injector balance test with a pulse box where you watch the pressure drop/fuel delivery of each injector. Look for less tan a 1.5 psi spread with a target around 3X psi. Consider measuring injector coil resistance and look for a target of 11-14 ohms with a range of less than 3 ohms across the injectors.
George
I like that process a lot, thanks for the reply! I just finished swapping the #4 and #6 injectors just to see if the problem would move. Rather unexpectedly, my misfire is now on #1. So it definitely appears to be an issue with the spider, and perhaps one I can't rectify by just buying one injector. Might end up having to buy a new assembly, although they are a bit pricey.
Old May 17, 2022 | 04:33 PM
72Shadetree's Avatar
72Shadetree is on a distinguished road
Had similar problems the misfire is not letting it burn all the fuel. The distributor is bad about wearing out on these I replaced it and fixed my misfire after a complete tuneup didn’t fix it
GeorgeLG
Apr 14, 2023 01:50 PM
bagginses
May 27, 2021 11:41 PM
BCpointers
Jun 17, 2020 04:42 PM
kempo
Jun 1, 2019 11:31 PM
joejiz
Jul 31, 2017 05:25 PM
