Fuel issues????
Old Jan 24, 2010 | 04:43 PM
PINK JUNK's Avatar
PINK JUNK is on a distinguished road
Angry Fuel issues????
95 S10 BLAZER 4X4 W/ 4.3 WILL CRANK AND IDLE BUT IF YOU TRY TO DRIVE IT OR REV UP IT SPITS AND BACKFIRES SOUNDS LIKE CHOKING OUT AND I HAVE REPLACED PUMP, IN LINE FILTER, SOCK, SPARK PLUGS, DISTRIBUTER CAP, WIRES, IGN. COIL,O2 SENSOR, throttle position sensor, NOT THROWING ANY CODES AND DONT KNOW WHAT TO DO NEXT? anxious to fix this truck i would love for my wife to call and I not know why! bad trend!!!
Last edited by PINK JUNK; Jan 24, 2010 at 09:27 PM. Reason: chaned another part no fix
Old Jan 24, 2010 | 05:27 PM
rriddle3's Avatar
Try cleaning the EGR valve, idle air controller (IAC), and mass air flow sensor (MAF). And, please, don't use all caps. Nobody likes to be yelled at.
Old Jan 24, 2010 | 06:07 PM
Have you tested the fuel pressure, specifically the leak down rate? You should have 60psi with the key-on/engine-off and it should not drop below 55psi when the key is off.
No MAF on a 95 Rich.
Old Jan 24, 2010 | 08:13 PM
PINK JUNK's Avatar
what if the pressure does go under 55? im going to get a pressure gauge tomorrow we'll see!!
daemeon2
Jan 6, 2013 04:06 PM
99slobra
Jan 3, 2013 05:02 PM
95jblaze
Aug 27, 2011 03:46 PM
cruukedeye
Jun 4, 2011 06:49 PM
teal
Sep 14, 2004 05:26 PM
