Fuel leak from where?
Old Mar 27, 2011 | 07:21 PM
blazerblack's Avatar
blazerblack is on a distinguished road
Default Fuel leak from where?
I did some searching around but didn't see this problem anywhere.
The truck is a 96 blazer 4 door 4WD. It has been smelling like fuel for the past few weeks, but had presented no leak. Last night I parked on the road, and this morning I found a small puddle on the road under the drivers side rear door. I figured that I had a rusty line, but didn't find anything wet on the lines or the frame. Figuring that the fuel had evaporated already, I started the truck up to see where the leak was. Turns out it's leaking from the body, just under the drivers side rear door. So I'm wondering what the heck could be leaking from up there? My best guess is the EVAP system. Does anybody know what could be up there leaking?
Any help would be appreciated.
Old Mar 30, 2011 | 06:12 PM
Bump... anyone? I found the evap box, and it doesn't look like that could be my problem. I thought I read that there is a vacuum line that runs from the throttle body to the evap box, does anybody know if that could be run up in the body?
Old Mar 30, 2011 | 06:25 PM
No lines are run through the interior of the truck.
Try removing the EVAP canister and see if it is saturated. If it is, it isn't doing its job properly.
Old Mar 30, 2011 | 08:01 PM
rodono's Avatar
rodono is on a distinguished road
maybe also check the fuel filter and its fittings. it sits underneath on the driverside
Old Apr 2, 2011 | 09:22 PM
I'll check out the canister. It definitely not coming from the fuel filter, the leak is higher than any fuel lines are ran. I know it sounds crazy, but I witnessed the fuel dripping out of a seam in the body under the rear drivers door. I drove it around today and no leak, but still a fuel smell. Anybody know where that vacuum line to the throttle body is ran?
Old Apr 2, 2011 | 09:31 PM
rodono's Avatar
maybe also check your fuel tank vent valve at the front of the tank
Old May 23, 2011 | 04:07 PM
dgryboski's Avatar
dgryboski is on a distinguished road
I just replaced my puel pump, and I did something wrong with the fuel tank vent valve when I put the tank back up. When the tank is full, it leaks, and I think it's the vent valve (located on top of the tank, exactly where you say your gas is leaking).
Old May 23, 2011 | 04:10 PM
dgryboski's Avatar
To get to the fuel tank vent valve, you'll have to lower your fuel tank.
Old May 31, 2011 | 08:55 PM
mjt's Avatar
mjt
mjt is on a distinguished road
You know this vent doesnt even show up in the GM service manual on my 99. So many people have damaged it.
Old Jun 1, 2011 | 04:56 PM
step66's Avatar
Please also check the condition of the filler neck assembly itself-very conducivice to corrosion as well!
