Fuel line leaking
Seems I have a fuel leak in one of the lines
I haven't had a chance to drop the tank and look for exactly where but the small fuel puddle is forming under the rear driver's side door and the frame looks wet so I'm GUESSING its the line. Is there any problem replacing the metal lines with high pressure (fuel rated) rubber hose? I really don't have the time or coin to replumb the entire fuel line system (IF I can even find one)
Guest
Posts: n/a
Contact this guy and see if he will make you a piece from the filter back with the correct fittings. Mine went in the same spot. I re-did mine with copper. I did not see any way of putting the OEM line in without taking the body of the truck off.
GM Chevy GMC Pick Up Suburban Yukon Tahoe Fuel Lines | eBay
timmi79
Feb 19, 2013 07:37 AM
95jblaze
Aug 27, 2011 03:46 PM
