Fuel line leaking
Old Oct 10, 2013 | 10:04 AM
Raybz's Avatar
Raybz is on a distinguished road
Default Fuel line leaking
Seems I have a fuel leak in one of the lines
I haven't had a chance to drop the tank and look for exactly where but the small fuel puddle is forming under the rear driver's side door and the frame looks wet so I'm GUESSING its the line. Is there any problem replacing the metal lines with high pressure (fuel rated) rubber hose? I really don't have the time or coin to replumb the entire fuel line system (IF I can even find one)
Old Oct 10, 2013 | 12:29 PM
spittybays
Guest
Posts: n/a
Contact this guy and see if he will make you a piece from the filter back with the correct fittings. Mine went in the same spot. I re-did mine with copper. I did not see any way of putting the OEM line in without taking the body of the truck off.
GM Chevy GMC Pick Up Suburban Yukon Tahoe Fuel Lines | eBay
Old Oct 10, 2013 | 01:43 PM
Raybz's Avatar
I didn't even think about copper. And I was pretty sure ther is no way to run OEM easily... That's why I was thinking rubber from where it goes from nylon to the fuel filter
timmi79
Feb 19, 2013 07:37 AM
95jblaze
Aug 27, 2011 03:46 PM
amplexis_0081
Dec 28, 2009 11:17 PM
rsither
Aug 13, 2009 10:29 AM
ChevyFamily
Jul 10, 2009 06:41 PM
