Fuel line o-ring sequence order?
Old Sep 24, 2013 | 08:41 AM
pensfan74's Avatar
pensfan74 is on a distinguished road
Default Fuel line o-ring sequence order?
Hello again, I am in process of reconnecting the two fuel lines to the fuel meter body on the plenum and I wanted to know does anyone know the exact correct order the o-rings/washer/spacers go back on the fuel lines? I have read several posts and they vary on the order. Is it black o-ring then washer then yellow o-ring then spacer? Does anyone have a pic of it? Thanks for any help...
2000 Blazer 4.3l 4x4 4dr CSEFI
Old Sep 24, 2013 | 10:14 AM
burned's Avatar
burned is on a distinguished road
That is correct
Attached Thumbnails Fuel line o-ring sequence order?-mxigcs08aro_gm_intake_manifold.jpg
Old Sep 24, 2013 | 10:48 AM
pensfan74's Avatar
Thank-you sooo much burned. Nice pic I really appreciate it.
Old Sep 24, 2013 | 02:47 PM
For what it's worth, this might help too:
Attached Thumbnails Fuel line o-ring sequence order?-csfiinjector.gif   Fuel line o-ring sequence order?-aa276de6-b436-40b8-a9f3-fd40330c295d_zpsiih05mgb.gif
Old Apr 18, 2016 | 01:59 PM
argillite's Avatar
argillite is on a distinguished road
Default o rings
Now, where can you purchase the o rings?
Old Apr 18, 2016 | 03:24 PM
This kit has everything you could possibly need to reseal the fuel metering block: Dorman - Help Fuel Injector O-Ring Seal Kit 90000: Advance Auto Parts=
Old Apr 18, 2016 | 06:56 PM
argillite's Avatar
That sure looks like everything is there. Thanks
Old Apr 18, 2016 | 07:01 PM
argillite's Avatar
Default spider injector
Another problem! Stud in top of spider injector that nut goes on that holds hold down plate for lines in spinning in plastic of injector. I can't tighten down nuts on plate enough. Any ideas how to fix short of changing entire injector?
brians1bad72
23
Jan 10, 2014 10:06 PM
1sttimejimmyowner
Nov 1, 2013 11:37 AM
echo1
Aug 10, 2012 11:36 PM
alesv
Apr 12, 2010 11:21 AM
cperry2704
Dec 31, 2006 12:08 AM
