Fuel Odor In Cabin
Old Sep 3, 2019 | 07:55 PM
423CV23's Avatar
423CV23 is on a distinguished road
Default Fuel Odor In Cabin
This has probably been a subject of many questions in the past.
I recently performed an injector balance test. After the initial pressurizing of the rail I let it sit 30+ seconds to see if the pressure had any bleed down (for all 6 cyl). It did not.
Injector Balance results:
Cyl
1 58psi 42psi
2 58psi 42psi
3 58psi 43psi
4 58psi 42psi
5 58psi 42psi
6 58psi 42ps
I also performed the cylinder power balance test several times; there were zero misfires reported.
I checked for fuel odor around the tank and vapor canister; nothing.
I can detect a very slight fuel odor in the engine bay while it's running. I'm assuming there are no leaks in the injector/FPR system, or it would have shown as a drop in pressure during the injector balance test (correct??).
Where else could fuel cause an odor in the engine bay?
Old Sep 6, 2019 | 11:50 AM
Dr. Blazer's Avatar
Dr. Blazer is on a distinguished road
I had this happening last week and found a fuel leak due to a loose connection on the stainless steel fuel line(s) at the back of the engine compartment.
It was only visible with the engine running- I could see it dripping with a flashlight.
Tightening the nut solved the issue.
chevyriders
Jan 22, 2018 07:55 PM
thisspaceforbrent
Oct 14, 2009 12:57 PM
countryguy1713
Mar 5, 2008 07:11 PM
Chadoo951
37
Oct 20, 2007 09:44 PM
Partime Gearhead
Mar 5, 2007 09:34 PM
