Fuel pressure issue 95 Blazer
Old Sep 10, 2009 | 10:57 PM
sidewheeler's Avatar
sidewheeler is an unknown quantity at this point
Default Fuel pressure issue 95 Blazer
about 20k ago I had the fuel pump replaced with a GM pump. Recently the car will start just fine in the morning but if you drive it 3-4 miles and turn it off, it will not start. You have to crank and crank on it for like 10 times and then it will hit once then almost start and then it will start and run fine until you turn it off.
I hooked up the fuel pressure guage and this morning it was over 60 lbs when it started. went to breakfast and the pressure was down to about 55 lbs. could the FPR be causing this problem or do I need a new pump.
Old Sep 10, 2009 | 11:09 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
does it do this after its warmed up or cold? you might want to check the ICM on the coil
Old Sep 10, 2009 | 11:20 PM
I have replaced every thing that can be replaced including the trigger coil in the Dist.
Old Sep 11, 2009 | 02:17 AM
awe341's Avatar
awe341 is on a distinguished road
Have you had the engine scanned for any codes yet? Some pending codes don't always throw a SES light.
There could potentially be a problem somewhere in the EVAP system that is causing the hard starts when warm. It could be as small a thing as a bad gas cap, or a bad purge solenoid or even a cracked vacuum line.
Old Sep 11, 2009 | 05:32 AM
reelbroke2's Avatar
a dirty fuel filter will cause a no start too
cammed93
Jul 27, 2013 04:05 PM
zjo
Mar 16, 2012 08:03 PM
jimbob533
Nov 14, 2011 06:02 PM
steveiowa1
Aug 26, 2010 07:10 PM
Spartan66
Jul 11, 2008 02:34 PM
