fuel pressure problem!! please help
Old Jun 1, 2011 | 07:01 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Originally Posted by silver bullet80
what are the chances that my rubber hose on the fuel pump is bad or has a small hole? would that cause driving problems?
Pretty good, actually. In the last month, 3 members of the Astro forum have had to replace that little piece of hose because the ethanol now in fuel ate it up. The pump was fine.
And yes, not getting enough fuel to the engine, especially under load, would definitely cause drivability issues.
Old Jun 2, 2011 | 09:57 PM
silver bullet80's Avatar
silver bullet80 is on a distinguished road
see the wierd thing is that if i get on it then it does fine but when im driving at normal speed like 55mph it surges. but like today it didnt do it all the time just every now and then? could this be a electrical problem? also noticed that when it starts surging my tourge convertor will unlock then maybe 10 miles later it kicks back in?? please help me
Old Jun 3, 2011 | 09:45 AM
mierze's Avatar
mierze is on a distinguished road
as far as i know, egr only kicks on when cruising, so during WOT conditions, the symptoms of a bad egr valve wouldnt be present. as for your pressure issue, make sure you check everything first before you condemn the fuel pump. i had the exact same pressure loss you do, and it turned out to be a bad fuel pressure test port schrader valve. 5 bucks at NAPA versus 300 for a new pump is kinda nice. also check the inside of the intake plenum for pooling of fuel, a common sign of a bad FPR. i understand it was replaced recently, but could be defective or improperly installed. or you could hook up your fuel pressure tester where the filter goes and and find out if you leak is tank side or engine side.
Old Jun 3, 2011 | 08:03 PM
ok so what your saying is that since it only seems to happen at crusing speed that it could be just a faulty EGR right? ive pulled plenum again and their are no signs of washing or puddels i even turned the pump on a few times to confirm their was no leaks near regulator and nut kit and its all good. we drove the blazer today before i did this and it ran great for awhile then it would do its little surge and then it would run great again? ive cleaned the egr very very good and still no change. ive cleared the code for the egr by removing the battery cabels both of them for over 15 mins but after driving for about 15-20 mins it throws the egr code again?
also i looked on autozone and the fuel pump doesnt cost no $300?? am i missing something here? when we bought this blazer about two years ago he said he just installed a new fuel pump too? im guessing he bought it at autozone?
Old Jun 4, 2011 | 09:25 AM
mierze's Avatar
what EGR code are you getting? is it insufficient flow? or something else? it might not be the valve itself. could be the wiring, or maybe its not getting an input signal. i havent had to replace my pump yet, but from everything ive heard on here, you dont want to go with a chinese one from autozone. theyre crap. spend the change and get an AC delco. theyre about 300.
Old Jun 4, 2011 | 10:22 AM
im getting the P0401 code it says on the ticket autozone gave me that it has detected to little flow on the egr system. and it says probable cause is blocked passage or failed egr valve. wiring all looks good and ive cleaned the egr. and where do i find these ac delco pumps or delphi pumps?
Old Jun 4, 2011 | 12:11 PM
When you cleaned the egr, did you clean the holes on the intake where it mounts?
Delphi/AC Delco pumps are available at Rockauto.com and getgmparts.com
Old Jun 4, 2011 | 01:55 PM
i cleaned them as much as possible but i couldnt get it all. i guess i could take it off again and clean it again. maybe something got in their again?
Old Jun 4, 2011 | 08:21 PM
chaoticdopey's Avatar
chaoticdopey is on a distinguished road
if you get the pump from rockauto they only have delphi but only as the fuel pump hanger assembly. next best thing is the spectra for $108 full assembly
SPECTRA PREMIUM Part # SP112A1H Includes Fuel Pump, Sender, Float and Strainer
Old Jun 5, 2011 | 03:44 PM
ok check this out. laqst night it rained and this morning the blazer ran like poop. if you take off like a normal person it would keep surging worse than ever but if u get on it like WOT it felt fine? now yesterday it was actually running pretty good since it hadnt rained for a week? now i do have a hood scoop that is open in front and rear. is it possible rain is getting on something to cause this? i popped the hood and everything looks dry like the dizzy and stuff so what else could be my problem? it deffinatly seems worse when it rains.
