Fuel Pressure Regulator Spraying Fuel
I have a 95 GMC Jimmy that broke down last night that was obviously due to a ton of fuel being dumped into the intake. I took the top of the intake off and the regulator is spraying fuel “full stream” out of the hole that’s open to vacuum. Threw on a new regulator and the same problem. Threw on a spare injector with a different regulator and same problem. Seems like the fuel can’t return to the tank and it’s building pressure. Any ideas what’s wrong? It’s the central port injector setup.
I never heard of a return line being blocked but there can be a first time for everything.
I'm afraid I am not much help with this but msybe someone else can offer some advice on how to diagnose the problem.
The rubber return hose back at the fuel tank( on outside of tank) was twisted over causing blockage. Pulled line loose and straightened it out and slid it back on. That is all. Put it on a lift and looked on top of tank and that's all it was . Nothing inside blocking rubber hose. The metal lines are real close to transmission and could easily get mashed when changing transmission. Good luck
Wreckmaster070202
03-07-2022 04:07 PM
laidblazer
06-09-2010 05:17 PM
bob51
07-04-2008 09:41 AM
maki3242@gmail.com
04-25-2008 12:47 PM
