Fuel Pump?
Old May 26, 2010 | 09:54 PM
blazin_j's Avatar
blazin_j is on a distinguished road
Default Fuel Pump?
Was driving home when all of a sudden complete loss of power, and then eventually stalled. Just barely managed to make it home. I turn the key and I can hear the pump priming, it will start but only for about 5 to 10 seconds and then just die. It has been misfiring for a while to. Any ideas? Thanks.
Old May 26, 2010 | 10:10 PM
Which one of the trucks in your sig is this on?
Regardless, a fuel pressure test would be a good place to start.
Old May 26, 2010 | 10:47 PM
blazin_j's Avatar
It's the Jimmy. Are there usually tell tale signs before a pump goes? I also forgot to mention that right before this happened I loaded a really heavy dresser in the back and dropped it in, could that cause something to come loose? I actually forgot about the Blazer, I need to do something with that. Anyways I have a friend with a pressure tester that's going to help me this weekend, keeping my fingers crossed. And would a fuel pump from a 95 work in a 97? Thanks.
Old May 26, 2010 | 10:48 PM
It's highly unlikely that loading anything into the truck would cause the pump to stop working.
And the pump likely will not work. Without looking up PNs, etc, I can't say for sure. A little bit of time comparing things on RockAuto.com should give you the answer to that question.
Old May 31, 2010 | 07:44 PM
blazin_j's Avatar
Problem solved. MAF electrical connection worked itself off just enough for me not to notice. Glad it wasn't the fuel pump. Just waiting to see what will go wrong next.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
