Fuel Pump or Assembly?
I'm getting conflicting answers. No sound from fuel pump when you turn the key forward. So pump is bad. One mechanic says you need the whole assembly, like this one:
http://shop.advanceautoparts.com/web...2AMS_992892779___
Another says all I need is the pump itself, like this one:
http://shop.advanceautoparts.com/web...J_P%7CGRP2030P____
There is a $360.00 difference in cost between the two parts.
1998 Blazer 4x4
4 door
4.3L
V6
Thanks in advance...
1998 Blazer 4x4
4 door
4.3L
V6
The second one is a mechanical pump. It is not for your car. Any decent pump for the new 4.3s is between 3 to 400 dollars and is located in your fuel tank. If a mechanic is really telling you to get the second one then slowly back away from him and NEVER EVER EEEEEEEEEEEEEEVER, go back to his shop ever again. The mechanical one does not make noise anyway regardless if it is working or shot.
Some one has their wires crossed. I think he either told you wrong or you misunderstood what he was telling you. The 2nd one will not work on your vehicle. It is a mechanical pump for a carbuerated engine, not a fuel injected engine.
That mechanic may have meant the electric pump only instead of the assembly with the fuel guage sending unit etc.
BouncingRadical
14
11-27-2015 01:30 AM
cide
11-07-2009 02:26 PM
junkmonkey
03-29-2007 09:01 PM
mytruck2
12-13-2006 05:50 PM
