Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Hose assembly from Air Pump
Old Mar 5, 2010 | 09:29 AM
siem1's Avatar
siem1 is on a distinguished road
Default Hose assembly from Air Pump
I put a new air pump & fuse in a '99 S-10, the hoses were cut off @ the pump on the old one. I found out there are no ports in the exhaust man. & no port by the cat. conv. nor diverter. Can a guy put a port in the exhaust so the vehic. is legal? The ck. eng. light is off now but the pump does nothing & the vehic. is not legal. ???
Old Mar 5, 2010 | 01:44 PM
neo71665's Avatar
Some of them came without an AIR pump. Sounds kinda like the exhasut manifold has been replaced on that truck for one without.
Old Mar 6, 2010 | 07:32 AM
siem1's Avatar
Thanks Neo, need to see if i put a port on the pipe just past the exhaust man. will it still be legal. It would save a lot of work.
Old Mar 6, 2010 | 08:13 AM
neo71665's Avatar
Since its not the factory design they might not pass it. Then again they might. Depends on the check station and how **** they are. If they are not **** about checking everything to exact detail I would prolly just return the AIR pump and run without it if its not throwing codes without it hooked up. As long as they don't run the VIN just tell them the bracket broke and you had to replace it with one that came off a truck with AIR.
It is illegal to remove that system so its up to you. I don't have to get mine checked and been running mine unhooked for years and don't plan on putting it back on my new engine when it goes in. Just one less part to tear up IMHO.
Old Mar 6, 2010 | 09:41 AM
siem1's Avatar
Thanks
djsgarrett
Mar 18, 2013 06:38 PM
rob1621
Apr 3, 2008 08:55 PM
slk34
Jun 28, 2007 10:07 AM
junkmonkey
Mar 29, 2007 08:01 PM
djbass_mekanik
Oct 26, 2006 09:12 AM
