Fuel Pump Connectors
I swapped out my fuel pump over the weekend. It was intermittent just after installation. I was able to isolate it to the connections at the pump. My fuel guage is also reading E after driving it a few miles.
Are the connectors typically supposed to be swapped when swapping the pump?
RE: Fuel Pump Connectors
those connectors can be sensitive, they could have been hurt during removel of the pump. but what are driving(year, eng), that info will help u more. but defintely sound bad
It's a `98 4.3L. It's no big deal.... I was just curious if these connectors were problematic. I saw where there was a TSB on some years where the connector at the fuel pump relay was problematic as far as it dropping some of the 12V which caused there to be a lack of current to the pump due to the lower voltage. This not being my case, I still wondered about the tank connectors.
BTW guys....here's an update that hopefully will help someone in the future. I pulled the pump on Saturday after measuring good voltage at the connector. I then bench tested the fuel pump and it was good as well. I also bench tested my original - good!! The connector female side had the contact bent down to the point where it wasn't making good contact with the pump. I pryed it up and reinstalled my original pump and I'm good to go. I also returned the new pump and got 300.00 back to boot!!!
wings4kites
04-27-2011 11:22 AM
99blklt4wd
02-03-2010 03:14 AM
pilgrim
01-21-2007 07:23 PM
