Fuel pump frustration!
Old Jun 24, 2015 | 02:49 PM
That's not necessarily a bad pump. Poor connections will cause intermittent or poor pump performance too. Could be a problem with power or ground for the pump. Pretty common problem is a bad ground on the top left rear corner of the frame where the pump grounds. Another is a poor connection at the pump module, (faulty connector).
Old Jun 24, 2015 | 02:55 PM
jjgrappler's Avatar
jjgrappler is on a distinguished road
Well originally had no power to the pump car would try to start just wouldn't turn over. Gas into throttlebody car would run. Now a new fuel pump and filter with the rewired connector car starts for about 10 seconds then idles down and dies. Going to get a fuel pressure regulator at autozone now.
Old Jun 24, 2015 | 02:57 PM
Might want to diagnose it before spending money. The link explains how to test it. Regulators rarely fail.
Old Jun 24, 2015 | 03:07 PM
jjgrappler's Avatar
So it should keep running even if the vent tube and filler aren't connected?
Old Jun 24, 2015 | 06:33 PM
On your 2001, the link shows how to activate the fuel pump from the underhood fuse panel with the ignition OFF. The pump must remain activated when the jumper wire is installed.
Old Jun 24, 2015 | 06:37 PM
jjgrappler's Avatar
Ok fellas I got her running good. Funny story I had the air intake off from putting gas into the throttlebody put that back on and boom she's running like a champ!!!
Old Jun 24, 2015 | 07:40 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
imagine that, it runs once its put back together..........
rbarden
Jan 14, 2010 07:20 PM
krisg
Jan 7, 2010 10:27 PM
david_catoe
Sep 16, 2009 04:34 PM
rubeninfl
May 8, 2009 09:31 AM
nova
Performance & Brainstorming
Apr 9, 2009 04:28 PM
