Frustration after replacing Leaf Spring
Old May 7, 2009 | 08:54 PM
rubeninfl's Avatar
rubeninfl is an unknown quantity at this point
Default Frustration after replacing Leaf Spring
First off, I want to thank everyone that helped me figure out how to take the spring off and put the new one on. Super thanks!
Now to the frustration. I originally did this because my drivers side rear was 3" lower than my passengers side. I took it to a mechanic that said it was the leaf spring. I decided to save the labor cost and do it myself. Well, I've replaced the "Bad" spring with a good one...and after all that work, the drivers side is STILL 3" lower..."ARGHHHH"
I don't get it. What else could it be? I can't figure it out. Does the shackle go bad? It appears to be at a similar angle as the one on the passengers side. Plus, I don't think I could move it since the leaf is connected to it.
I'm starting to think there was nothing wrong with the leaf spring I had on there although my truck does have 147k miles on it....and it was used to haul heavy stuff.
What should I be looking at?
Old May 7, 2009 | 09:12 PM
What is the measurement from the axle to the frame side to side?
What did the replacement spring come out of?
Old May 7, 2009 | 09:17 PM
rubeninfl's Avatar
The replacement came out of a 2005 2 door blazer with 14k miles on it. I'm not really sure about the measurement your asking. I'm trying to picture what you're asking. From the axle to the frame?
Old May 7, 2009 | 10:01 PM
Take a tape measure and measure from the top side of the axle to the bottom side of the frame.
And you are driving what? # of doors? What are your suspension RPO codes? Were both vehicles the same drivetrain configuration (2wd or 4wd)?
Old May 8, 2009 | 09:31 AM
rubeninfl's Avatar
well, some good news. I got it out on the driveway today ( I did the repair in my back yard...on grass). I checked and filled the air on all four tires and now the height in the back is off by less than 1/8 of an inch. I guess I can live with that. On the front end, the passenger side is about 1/2 higher than the driver side so that is probably where that 1/8 comes from.
Again, thank you everyone
CanadianaBlazer
Mar 30, 2014 07:00 AM
Leo_p
Apr 22, 2012 08:57 AM
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
krisg
Jan 7, 2010 10:27 PM
nova
Performance & Brainstorming
Apr 9, 2009 04:28 PM
