fuel pump/gas tank
Old May 27, 2009 | 03:59 PM
blkblazer's Avatar
blkblazer is an unknown quantity at this point
Default fuel pump/gas tank
Can anyone tell me how the fuel line at the center fuel pump connector comes off. I have the tank dowm everything is ready to come off except I cannot get the line to unhook at the center pump connector. I have all the other lines disconnected.
Is it different type connector than the other clips? Do I need any tool?
Thanks
1999 S10 blazer 2 door LS auto 4.3l 4x4
Old May 27, 2009 | 04:01 PM
It is the same quick disconnect type connector and will release just like the others if you can get the tabs to release. I just use a small screw driver to get them loose.
Old May 27, 2009 | 09:23 PM
If I remember right, that connector is the vapor line, (doesn't use the clip insert style), and it squeezes together using your thumb and index finger, then slide it off.
Smc
Nov 14, 2013 04:46 PM
wjdjake
Jul 17, 2011 02:06 AM
ericshaw
May 31, 2011 08:50 PM
degaine_designs
Aug 19, 2009 11:12 PM
SnowRemorse
Jan 4, 2008 11:26 AM
