Replacing fuel pump broke small ftg on gas tank
Old Dec 29, 2009 | 06:05 PM
ericshaw's Avatar
ericshaw is on a distinguished road
Default Replacing fuel pump broke small ftg on gas tank
I was not aware of the fitting on opposite end of fuel tank that has a small hose. The fitting is cracked not completelybroke off. Is this replacible or could I repair w/epoxy putty?
Old Dec 29, 2009 | 06:14 PM
leeclark's Avatar
leeclark is an unknown quantity at this point
i have a 98 blazer with metal tank and it was replaceable on mine its called a fuel tank vent valve here. maybe yours is the same.
Old Dec 29, 2009 | 06:37 PM
Definitely is replaceable, but you could repair it with epoxy as well.
Old Jan 1, 2010 | 10:38 AM
ericshaw's Avatar
My tank is plastic and GM can't find part. It shows and empty hole wear the vent valve is on the dealers illistration so he called MFG tech support for parts dealer and he sold me a vent valve but it won't work on this oem tank. I got some loctite epoxy and repaired crack. Vehicle is back together with new pump and starts even in the rain but the fuel pressure is only 58 - 59 with engibe off and 52 - 55 while runnig. Is there another problem or is that ok?
Old Jan 1, 2010 | 03:16 PM
leeclark's Avatar
if i'm not mistaken thats where its supposed to be when its running.
Old Mar 27, 2010 | 08:24 AM
2toneblazer's Avatar
2toneblazer is on a distinguished road
put pieces together insert nail or something to keep alignment & epoxy works great.
Old May 31, 2011 | 08:50 PM
mjt's Avatar
mjt
mjt is on a distinguished road
I have a 99 4 door plastic tank and its not replaceable. You need a new tank or repair. I plugged mine.
wjdjake
Jul 17, 2011 02:06 AM
Johnny Glenn
Apr 16, 2010 09:59 AM
degaine_designs
Nov 11, 2009 04:18 PM
hotrod413
Oct 4, 2009 11:48 PM
LittleT
Jul 17, 2008 10:04 AM
