Fuel Pump issue/ hard starting
Old Jul 21, 2009 | 02:37 AM
baggedchevy99's Avatar
baggedchevy99 is on a distinguished road
Default Fuel Pump issue/ hard starting
NEWS TO ALL, THE FUEL PUMPS AUTOZONE AND ORIELLY'S SELL'S CALLED AIRTEX ARE JUNK NOT TO MENTION THEY ARE RATED AT 40-55 FUEL PSI. GM STATES THAT THE BLAZER'S NEEDS 56+ TO WORK CORRECTLY!! ONLY THE AC DELCO/DELPHI ARE CORRECT THEY ARE RATED AT 62+ PSI!! HOPE THIS HELPS!! i found out the hard way!!!
Old Jul 21, 2009 | 03:11 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
a simple search would of told you the same thing...
Old Jul 21, 2009 | 08:26 AM
true but sometimes searches don't work as well as they were in intended to!!
Old Jul 22, 2009 | 10:11 PM
minijosh's Avatar
minijosh is an unknown quantity at this point
Kind of weird the guy at the Chevy dealership I was trying to order my fuel hose thru said the hose only does 50 psi. What sense would it make for the pump to push more than the hose can handle or was he just wrong?
Old Jul 22, 2009 | 10:57 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
why would you buy fuel hose from a stealership anyway?
Old Jul 23, 2009 | 06:27 AM
50psi? maybe after the regulator but not sure I was todl by a tech that a good fuel pump puts out 62+ psi and that the blazer had to have 56+ to start perfect and run!! So i don't know when 50psi came from!!
Old Jul 23, 2009 | 08:07 AM
minijosh's Avatar
Nobody in the Las Vegas makes this hose. I have to locate the plastic ends before anyone will make the hose. It's the one where the plastic clips hold the lines onto the fuel pump.
BouncingRadical
14
Nov 27, 2015 12:30 AM
sturj
Apr 23, 2011 02:53 PM
cgrett
Nov 15, 2010 09:08 PM
sweet-98ta
Dec 16, 2009 08:47 PM
Icarus76
Mar 5, 2007 01:28 PM
