fuel pump maybe? 95 s-10 4wd
Old Feb 21, 2010 | 09:22 PM
daron gorichar's Avatar
daron gorichar is on a distinguished road
Default fuel pump maybe? 95 s-10 4wd
first off i want to thank the guys who helped me get my tranny trouble dialed in. got it rockin now. my new problem i'm told is my fuel pump.mayby. so my s-10 used to fire right up,without fail or hesitation. hot or cold she would start. well recently the truck (95 s-10 4wd) sometimes will start after about 20 tries sometimes more, sometimes less. i replaced the fuel filter, recent full tune-up, air cleaner. any thoughts? thanks
Old Feb 21, 2010 | 10:43 PM
LowLife's Avatar
LowLife is on a distinguished road
Well the first thing to do is check the fuel pressure to make sure you have enough, If you do then i would say its your fuel injectors, My 97 bravada did the same thing until i changed the injectors. Hope that helps.....O and the fuel pressure test port is under your hood behind the throttle body it looks like a valve stem cap just bigger
88s10Blazer
Jan 22, 2010 01:07 PM
Alex01tib
Mar 26, 2009 02:11 PM
xAnarChisTx
Jun 4, 2008 10:49 AM
alexedge
Apr 6, 2008 12:51 PM
USMaverick101
Nov 17, 2006 04:06 PM
