fuel pump problem...maybe
Old Sep 5, 2010 | 11:13 PM
bryan101's Avatar
bryan101 is on a distinguished road
Default fuel pump problem...maybe
Symtoms:
Blazer starts and runs fine... when I turn it off it wont start back
Fuel pressure when it does start is about 60psi
pressure when it wont start is only about 20psi
could this be a fuel pump problem or is it something else?
I changed the coil pack and the fuel pressure regulator.
I am getting good spark and power to the injectors when it wont start.
Old Sep 5, 2010 | 11:40 PM
4x4blazerguy's Avatar
Have you done a leak test? I know you need 60 PSI to run correctly. There is a fuel pressure regulator, I believe it is located under the top manifold with the spiders.
Old Sep 6, 2010 | 12:59 AM
bryan101's Avatar
I have done the leak test.. it loses about 2psi in five min. from what I understand, that is within specs. I just replaced the the fuel pressure regulator yesterday.
Old Sep 6, 2010 | 06:52 AM
Sure sounds like the pump, but I would go over the power/ground to the pump first to make sure that it isn't something simple.
Old Sep 6, 2010 | 01:01 PM
bryan101's Avatar
I am going to check the electrical connections today. I will post back my results
the electrical connections seem to be fine. they were very tight, and clean. I didn't see any burnt spots or any signs of heat.
Last edited by swartlkk; Sep 7, 2010 at 04:39 PM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post if another member has yet to reply.
Old Sep 6, 2010 | 04:18 PM
nemesis's Avatar
nemesis is on a distinguished road
if it has voltage and ground and it holds pressure, try to run it on an alternative fuel source like fuel injection cleaner, if it runs briefly and stalls i would replace the fuel pump and fuel filter, also inspcet the fuel itself for contamination while the tank is down just to be on the safe side.
Old Sep 6, 2010 | 06:16 PM
bryan101's Avatar
I did try the fuel injection cleaner, and it would act like it was going to start. I have already replaced the fuel filter
BouncingRadical
14
Nov 27, 2015 12:30 AM
realpriddy
Aug 14, 2012 01:28 PM
88s10Blazer
Jan 22, 2010 01:07 PM
alexedge
Apr 6, 2008 12:51 PM
USMaverick101
Nov 17, 2006 04:06 PM
