fuel pump question
Old Jan 22, 2010 | 07:47 PM
moldeck's Avatar
moldeck is on a distinguished road
Default fuel pump question
I have a fuel pump that I cleaned off the top of it. There is a black electrical plug (three wire) that I believe is the fuel presure switch. While I was cleaning it I relized that this piece has a **** on the top that turns. I relized after getting it very clean that I had been turning it the whole time. Is this an adjustment for this switch?
97 blazer 4.3 4 door
Old Jan 22, 2010 | 07:54 PM
Sounds like the vent to me.
Old Jan 23, 2010 | 02:23 AM
moldeck's Avatar
Default ok one more
New pump is in and no fuel to carb, i am working on getting a presure gage, but the check valve under the hood is not producing any fuel when pushed. Pump is running, I wired in the new pump with a new conector and there was no markings on the two black wires, Matched the other two, purple and gray. Is it possible the pump is running in reverse??
I put a new filter in 3 weeks before the new pump. I will most likely change the filter again. What is the best way to check presure/fuel at the filter?
should I have to bleed the air out of the line after the new pump. I changed this pump once before and do not recall doing that.
Any suggestions?
It will start with gas dumped into the carb, but stalls out when its burned out.
Old Jan 23, 2010 | 02:46 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Wire colors are for the fuel pump and sender. Black is ground, purple is the sender wire to gauge and gray is the hot wire to the pump.
Old Jan 23, 2010 | 03:05 AM
ohsofly's Avatar
You could just unhook the fuel line at the filter, and turn the key, if the pump has good pressure, it should spray gas all the way to your front wheels, that pump can put out a litre in about 15 seconds so dont leave the key on for long... Make sure you are not smoking and somewhere ventilated though.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
