Fuel Pump question
Old May 19, 2013 | 06:07 PM
Tyler L Harstine's Avatar
Tyler L Harstine is on a distinguished road
Default Fuel Pump question
Hey I have a second generation blazer that I need to get the gas out of and have decided that the easiest way to do this would be to put power to the fuel pump and pump it into a container. What I need to know is where exactly would I jump the power to? I believe what I am looking for is a relay to jump the power to but not sure where it is located. any advice or help for me?
Old May 19, 2013 | 06:09 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
glove-box when you turn the key after about 3 secs listen for a click thats the relay you want
Old May 19, 2013 | 06:25 PM
do you know right off which pin i would want to jump the power to?
Old May 19, 2013 | 07:08 PM
I actually just looked under the hood and found a f/pump relay in relay/fuse center lol
Old May 19, 2013 | 07:20 PM
anybody know how exactly i should go about this? thinking wiring power and ground from battery to the power and ground pins under the relay
Old May 19, 2013 | 07:21 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
just jump the pins in the connector
Old May 19, 2013 | 07:25 PM
yeah thats what i was thinking. now if itll ever stop raining i can grab my gas can and go drain that bish. so I take it that one of those pins under that relay is hot all the time?
Old May 19, 2013 | 07:57 PM
Yes, you may need the key on, i'm not sure. But there are the terminals for the switch and for the fuel pump's power and ground that the relay connects when the switch for it is engergized. Jumping the connectors for the pump is the same as the relay activating.
Old May 19, 2013 | 10:44 PM
cleburne red's Avatar
On my '95 there is a connector for this on the driver side inner fender. It's a female connector that doesn't go to anything. Put 12V to it and it energizes the pump. No need to mess around with relays. There is a cover right above the connector that comes off, and there is supposed to be a 12V supply in there, but I had a long jumper and just ran it from the battery.
It think it's different on the later second gens, though.
probably a good idea to have some sort of fusible link in the jumper, as well. I didn't, but ya never know.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
