Fuel Pump & Radio
Old Mar 25, 2007 | 10:10 PM
snyderman402's Avatar
snyderman402 is an unknown quantity at this point
Default Fuel Pump & Radio
1995 Blazer- Sometimes it would start fine, Sometimes would take a couple of cranks. Is there any connection with the wiring, and the radio? I found out I had a bad fuel pump by checking this site for problems, but I can't figure out why my radio would freeze on a station (the volume too, I couldn't chage stations, volume, or turn off radio when it would freeze. It would still play even when turned off.), and the radio wouldn't work for 6-8-10 to 24 hours after it would freeze, and the ignition was turned off then back on. Since I changed my fuel pump, I've had no problems with the radio! Is there any connection?
Old Apr 4, 2007 | 06:39 PM
hillbillyinOhio's Avatar
Default RE: Fuel Pump & Radio
none whatsoever. no clue on this one
Old Apr 4, 2007 | 07:21 PM
Zygoat's Avatar
Zygoat is an unknown quantity at this point
i think the only way they could effect each other would be if the whole electrical system had some big problem, or if the circuts were somehow contacting each other.
Old Apr 5, 2007 | 11:54 AM
filstoy's Avatar
filstoy is an unknown quantity at this point
Did you disconnect the battery when you changed the pump ? If so, you probably cleared the processor or a related IC in the radio.They can crash just like a computer. If you're lucky it won't come back but I wouldn't be surprised if it shows up again eventually.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
