Fuel pump recommendations?
Old Jun 26, 2009 | 09:33 PM
backnblack99's Avatar
backnblack99 is an unknown quantity at this point
My fuel pump went bad too. I was thinking bout goin with the inline? Why is the 2door fuel pump higher that the 4 door blazer!
Old Jun 26, 2009 | 10:53 PM
IF you can find an inline pump that will supply sufficient pressure and volume, you'll need to drop the tank and modify the pick up on the old pump module, (the inline pump will not pull fuel through the old pump. As with most things, there's more work involved to cobble it, than to fix it right.
The 4DR tank is midship, inside the frame. The 2DR tank is aftaxle. Different tank configurations, and the fuel pump modules are NOT interchangeable.
Old Jul 6, 2009 | 05:15 PM
mudnsno's Avatar
mudnsno is on a distinguished road
I just got a 2000 4dr 4wd Blazer. Needs work. I need to replace left front hub, and probably a fuel pump. I am still diagnosing that problem though. Driver window not working motor or switch (worked when I bought it)..
In re to fuel pump, I have read quite a few posts re Delco vs aftermarket. I do much prefer OEM but the Delco price is a shocker; about $300 here locally. Has anyone any experience with the following website: http://klova-autoparts.tripod.com/klova/index.html
They have Delco MU85 at $165. I just now emailed to ask if this is a genuine new Delco part.
Also, any suggestions the window issue?
BouncingRadical
14
Nov 27, 2015 12:30 AM
Kainon
Dec 13, 2010 11:27 AM
azblazer89
Aug 25, 2008 03:54 PM
jamesaz
Jun 24, 2007 11:14 PM
viper4559
Jun 7, 2007 06:18 AM
