fuel pump wont turn on
Old Apr 22, 2009 | 03:03 PM
anna's Avatar
anna is on a distinguished road
Default fuel pump wont turn on
I have a 2000 blazer and I replaced the fuel pump about three years ago. This December it wouldn't start because the fuel pump wouldn't turn on. After sitting for about a month I went out to try to start it and it worked fine. Last week I tried to start it and the fuel pump wont turn on again. Any suggestions?
Old Apr 22, 2009 | 03:15 PM
Nothing that has not been covered in quite a few other threads.
Check the relay. Other than that, you are probably looking at a new pump. What brand pump did you install 3 years ago?
Old Apr 24, 2009 | 01:48 PM
anna's Avatar
All of the mechanics I have called said they wont test the relay without the truck being there so I haven't been able to check the relay yet. I don't remember what brand, I bought it from Shuck's Auto Supply for about $400.
Old Apr 24, 2009 | 06:30 PM
Swap the fuel pump relay with the horn relay and try to beep the horn.
Old Apr 27, 2009 | 06:14 PM
anna's Avatar
so my blazer sat for about 3 weeks, I went to test the relay and before I did that I tried to start it and it turned right on and it started...wierd
Old Apr 28, 2009 | 08:24 AM
Sorry to say, but this is most likely a pump problem. But by all means, test the electrical system out.
Old Apr 30, 2009 | 05:55 PM
anna's Avatar
So it worked fine for a few days until today. I drove it to school and when I went to go home it started for about 10 seconds, then died and now it wont start again..what the heck? Time to replace the pump again?
Old Apr 30, 2009 | 06:44 PM
Test the fuel pressure. Key on, engine off, pump running, pressure must be 60psi to 66psi. It must remain above 55psi for 3 to 5 minutes after the pump shuts off. Post your results.
Old May 4, 2009 | 05:37 PM
shaunbrown1979's Avatar
shaunbrown1979 is on a distinguished road
Sounds like the pump is going out... a three year old pump may not last long if the fuel filter is clogged too...
Old May 15, 2009 | 12:19 AM
anna's Avatar
We re-grounded the ground wire and it worked fine for a few days and then stopped working again. A friend said on his Blazer he had to put some lubricant on a plug in the fuel pump because his was doing the same thing as mine and now his works fine. He has a 4-door though so he can reach his fuel pump, I have a 2-door so I'll have to drop mine to try it.
