fuel pump wont turn on
Old May 15, 2009 | 12:42 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
have you tried any of the suggested tests?? you may just have a bad fuse like kyle (swartlkk) said and there may be no reason to drop the tank, also test the psi (this can be done at home) that way youll know for sure if you have to drop the tank or not. i always though you had to drop the tank regardless if its 4dr or 2dr unless ur friend has cut some sort of hole in the cargo area. if you do end up replacing the pump go with ac-delco and change out the fuel filter while ur down there.
BouncingRadical
14
Nov 27, 2015 12:30 AM
Klturi421
Jun 29, 2012 10:20 AM
waviaerith
14
Oct 16, 2011 09:05 PM
ZR2SuperDiggers
Jul 2, 2009 09:25 PM
jetsmy
Aug 1, 2008 10:10 PM
