Fuel smell after replacing pump
Old Nov 20, 2017 | 12:50 PM
McCormick_4723's Avatar
McCormick_4723 is on a distinguished road
Default Fuel smell after replacing pump
I replaced the fuel pump omy 95 blazer and have started to notice a fuel smell when starting and when stoped at stop signs...the lines should be fine and the two vacuum lines are hooked up...When I took the old pump off I noticed that it was covered with some sort of sealant like the entire top of the tank was sprayed with almost a tar ....im guessing it was done at the factory and am wondering if I should spay some under coat or something on top of the tank to try and reseal it again??????
Old Nov 20, 2017 | 04:11 PM
chevyriders's Avatar
Did you make sure to put the new rubber seal in with the pump? Sometimes it's the simple things that get overlooked
Old Nov 20, 2017 | 05:08 PM
jck1961's Avatar
jck1961 is an unknown quantity at this point
Did you connect the rubber hose to the vent located in the front of the tank?
Terje
Nov 4, 2017 08:19 AM
bsbob
Aug 18, 2011 05:11 PM
benshuey
Jun 19, 2010 05:22 PM
cide
Nov 7, 2009 01:26 PM
chrisblaze
May 23, 2009 02:21 PM
